mookaloid
| posted on 4/6/06 at 09:22 PM |
Pinto head gaskets
To add to my woes (see previous post) My head gasket seems to be leaking - again
Anyone happen to know about these?
I really don't want to have to spend £170 (burtons cometic)
what is a wills ring gasket? what are the advantages?
is the original ford gasket better than those from the local motor factors for a tenner?
Advice appreciated
Mark
nitram38
| posted on 4/6/06 at 09:43 PM |
A wills ring is a copper hollow ring/hoop.
In order for it to work, a groove needs to be cut around each piston, both in the head and the block. The ring is then sandwiched into this groove
when the head is tightened. I have used them on imp engines for racing.
This is not an amateur job.
More than likely, your head may need skimming, but on the pinto, this will depend on valve clearances on your pistons. Again best left to a proper
machine shop/engine builders.
mark chandler
| posted on 4/6/06 at 09:59 PM |
A decent felpro gasket should do the trick, if these leak you need a skim.
a quick google later:
Head gasket FELPRO Ford 2.0 Pinto up to 93mmm FELPRO, TAS0389, Up to 2060cc, £22.95. 600, Head gasket set Ford 1600 X-Flow RWD, PAYEN, DJ202, £17.95
www.speedshack.co.uk/Flash/ downloads/3-6-03%20Retail%20Catalogue.xls
Regards Mark
mookaloid
| posted on 4/6/06 at 10:13 PM |
thanks guys
Dusty
| posted on 5/6/06 at 12:55 AM |
I had long running problems with what seemed to be an overheating problem. Blew water out the rad at 80+ mph. No water loss otherwise, no water in
oil, no oil in water, no loss of compression. I changed the head gasket, water pump, thermostat and even fitted a larger rad. Eventualy had the head
crack tested and it was OK but the machine shop said the would give it a skim to make sure. Solved. Pinto heads do warp.
If you seem to be having recurrent head gasket problems get it skimmed.
| posted on 5/6/06 at 07:18 AM |
A Wills ring is an alloy steel ring of slightly larger than the cylinder bore formed from capilary tube with the ends are butt welded together, the
really important feature is is is filled with nitrogen at around 2000 psi so acts a gas spring.
Each ring sits in a groove machined in the head so that when bolted down against the block it forms a seal with the cylinder liner. Water and oill
passages are sealed by paper gaskets and rubber O rings.
Will rings allow more expansion movement between the head and were particularly succesful on racing Imp engines.
[Edited on 5/6/06 by britishtrident]
| posted on 5/6/06 at 09:25 AM |
FWIW They can be mild steel, stainless steel, copper or Inconel depending on application. They are used in all sorts of industrial sealing
applications as well as cylinder heads.
NS Dev
| posted on 5/6/06 at 09:55 AM |
a cheaper and simpler and just as effective on engines alternative is plain wire ringing.
Here the block face only is grooved, the head is left flat, and the grooves are filled with a copper wire. A normal head hasket is used and the copper
wire reinforces the flame ring on the std head hasket.
The grooving can be done in situ with the head off and something in the bore to catch the swarf.
Iskanderian used to make the tool for cutting the grooves, a fair few engine builders will have them.
flak monkey
| posted on 5/6/06 at 11:34 AM |
Seeing as you have upped the compression ratio i am guessing a std head gasket wont last long in your engine.
Perhaps a Felpro or Ajusa competition head gasket is the way to go? Got to be worth a try, especially seeing as the Cometic ones are and obscene
amount of money!
Sera
http://www.motosera.com
