Author: Subject: megajolt
rosey
posted on 5/6/06 at 06:54 PM Reply With Quote
megajolt
Hi there sorry to be thick but what is a megajolt and what do they do
thanks paul
rayward
posted on 5/6/06 at 06:58 PM Reply With Quote
its an ignition controller,basically replaces the distributor on your engine,and controls the advance/retard of the spark timing(normally using a ford EDIS unit and coilpackin place of your ignition coil)
a megajolt is programmable,and takes into account engine load and varies the timing to suit.
hth
Ray
[Edited on 5/6/06 by rayward]
rosey
posted on 5/6/06 at 07:01 PM Reply With Quote
megajolt
is it easy to fit and what differance will it make to performance
rayward
posted on 5/6/06 at 07:04 PM Reply With Quote
depends how good you are with wiring, you will definatley see and improvement over a standard dizzy.
Ray
Danozeman
posted on 5/6/06 at 07:38 PM Reply With Quote
Megajolt is easy to wire up especially if u are running a zetec which has the crank sensor already there. Otherwise you have to have a trigger wheel on the crank pulley.
Have a look here
It will help you with what u need to know.
Dan
tim windmill
posted on 6/6/06 at 07:04 AM Reply With Quote
we have just fitted megajolt to a pinto and are delighted with the results as well as fitting bike carbs
