Author: Subject: megajolt map with TPS for Zetec
fellowes
posted on 10/6/06 at 01:06 AM Reply With Quote
I have a set of R1 yamaha Carbs on a 2.0L zetec engine. What values has everyone used for setting the TPS for the 10 different load sites?
Does anyone using a map for the above engine with some head porting and stage 2 cams w/ headers?
viatron
posted on 10/6/06 at 07:11 AM Reply With Quote
No matter what map you get it is unlikely to have the right values for your TPS. Connect up a pc/laptop and run up the software and go to tools, runtime display.
You will be able to view the TPS value change as you move the pedal, take a note of the value with the pedal at rest and again with it pressed to the floor! This now gives you the first and last value for TPS, just divide the rest up between the remaining 8 cells.
Mac
tim windmill
posted on 10/6/06 at 07:15 AM Reply With Quote
as previous post find min and max throttle position values from run time display and go to www.cat1.co.uk website and enter these values into the converter and it will give you the 10 bin values
viatron
posted on 10/6/06 at 10:35 AM Reply With Quote
The site you posted should have been www.cate1.co.uk
Mac
