donut
| posted on 10/6/06 at 10:56 AM |
BHP of a Landy V8?
Does anyone know the BHP from a 3528CC V8 Engine removed from a 1988 LAND ROVER 110
Danozeman
| posted on 10/6/06 at 10:58 AM |
10bhp
Are you looking at getting another engine to get rid of?
Dan
donut
| posted on 10/6/06 at 11:08 AM |
ha ha!! yes very good.... but kinda true as i do have a bit of a reputation where 4 cylinder engines are concerned but a V8 is very different and
i'm gonna put one in my Indy...at some point.
stevec
| posted on 10/6/06 at 11:16 AM |
There is a bit about them halfway down this page Andy.
Steve.
http://www.lrfaq.org/Series/FAQ.S.Engines.html
graememk
| posted on 10/6/06 at 11:33 AM |
depends on how many people are pushing it
ReMan
| posted on 10/6/06 at 11:37 AM |
91 BHP!
Your gonna need 2 of them then
donut
| posted on 10/6/06 at 11:42 AM |
ooooh thats a bit pants!!
Why is it that the local engines are always the wrong ones to get
Humbug
| posted on 10/6/06 at 12:46 PM |
Isn't that what the guy had in his Viento at Newlands last Sunday (wilkingj)?
donut
| posted on 10/6/06 at 12:58 PM |
Yep!! Sounded lurvley.
Heres a pic of an Indy with the RV8
DIY Si
| posted on 10/6/06 at 01:37 PM |
I thought the landy v8 was tuned to produce more torque but less bhp? Could be wrong though. I thought the sd1 v8 was the better version for
'our' use? Unless you can find a tvr version lying about handy....
donut
| posted on 10/6/06 at 03:26 PM |
The SD1 is the better version and i did find a Westy with a 4 litre TVR engine detuned to 300bhp!!!!
Pezza
| posted on 10/6/06 at 04:12 PM |
sd1 was 155bhp new according to rover
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
bob
| posted on 10/6/06 at 04:21 PM |
When you say that YOU are going to fit a V8 in your indy i'm a bit confused now.................. are you going to swap bodies with someone who
can
mark chandler
| posted on 10/6/06 at 08:27 PM |
Landrover v8, early is around 100bhp, this is the 8.25:1 comp, although the engine is identical to the later landrover 135bhp ! The early ones had a
restrictor in the inlet (which can be dragged out) directly in front of the carbs.
Range rover V8 is a better choice as you get 9.75:1 comp ratio, same valves as and SDI with slightly milder cam, swap this with a 3.9 cam and you are
back to 165bhp. Bit of fettling with the heads and exhaust with a 3.9 cam gives 200bhp.
What you need to do is look where the dipstick goes into the block, this is in goes through a machined flat with the comp ratio stamped, if its got
9:75 then you are generally okay, avoid any engine with 8:xx
Regards Mark
caber
| posted on 11/6/06 at 09:32 PM |
Any RV8 in basically any good nick can be fettled as far as your budget. Look in rocker covers if they are full of brown goo go find another alsu
check waterways for white crap again be careful both of these are signs of poor maintennance, insufficient oil changes or water rather than 50%
anifreeze.
Once you have a basic engine in good nick there are many resources for tuning, lots on the web or in any Landrover mag
Caber
locostv8
| posted on 11/6/06 at 11:11 PM |
I don't know the availability in the Uk but a Locost I know of used a Ford 302 I believe with steel heads and his weight came out 1250 lbs with
50/50 weight distribution, the chassis was a +4 and he should have done a bit more reinforcing. I plan on building one with a 351 using an aluminum
head and flywheel which should come out about 450 lb for the engine which is about the same as the Tbird Turbo coupe (pinto 2.3) engine but with
atleast 100 hp more.
[Edited on 11/6/06 by locostv8]
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
| posted on 12/6/06 at 07:14 AM |
to answer original question, it is listed as 116 bhp, CR 8.13.
The engine referred to above, it is stage 1 and millitary - restrictors were put in to prevent the army from going too fast in them!
Increasing CR is matter of swapping in the pistons. As said, RR engines are more powerful, starting with 135 and 163 bhp before going on to larger
bore/stroke engines.
SD1 vitess, efi put out 194 bhp.
blueshift
| posted on 12/6/06 at 03:49 PM |
I got a vitesse efi I thought they were 180bhp though. 10ish more to be had if you changed to an non-flapper airflow sensor type (carbs or hotwire
MAF), more again with exhaust mods.
however it has languished for many months not in a car doesn't make any bhp at the moment. lazy me.
Fred W B
| posted on 12/6/06 at 06:12 PM |
This
would be nice, if we could afford it. Why bugger around with worn out lumps if you can buy it new
Fred W B
4.8 Turnkey Engine 300 BHP+ Spec
HC 4.8 Litre (Fully Balanced)
BV Stage 3 Ported & Flowed Heads with bulleted guides, HD Springs, Craneretainers, locks & neoprene stem seals.
New Steel Rocker Assembly
Crane HD Pushrods
Fast Road or High Torque Camshaft
Rhoads Lifters
Duplex timing set
Rocker Covers
Mallory Dual Point Distributor + Coil + Ballast or Mallory Electronic or MSD Ignition
Resistor,Leads & Spark plugs
Short Front End Assembly - complete
Edelbrock 500 Carb Kit + 10 or 14" Chrome Air Cleaner, Thermostat housing, ARP bolts
4-1 Tubular RR Headers
Trapdoor Sump
Water Pump, Alternator + brackets & Belts
HD Starter Motor
All Gaskets, seals and new bolts throughout
Steel Billet flywheel & Super Duty clutch
5.0,5.2 & 5.4 Litre units also available - please ask
£5,295.00
All prices include VAT @ 17.5%
[Edited on 12/6/06 by Fred W B]
