Krismc
| posted on 12/6/06 at 08:58 PM |
ZETEC alternator belt!!
im looking for a 995-1000mm belt 5 groves for my 2.0zetec!! can anyone help or are i going to have to pay racelines £17 for one the robbing bstards
Agriv8
| posted on 12/6/06 at 09:38 PM |
will second Calvinex on that.
took mine around to the local parts man sam said i wanted a 5 grove belt at x long just between 2 he had on the shelf so walked away with both for
less that a tenner.
regards agriv8
Dusty
| posted on 13/6/06 at 12:08 AM |
Halfords also have a big range to choose from.
stevebubs
| posted on 13/6/06 at 12:09 AM |
Halfords Part number will be HB<length>g
g means 6 rib / 5 grooves
length will be 995 for 995mm, e.h.
HB995g
HB1000g
Stephen
roadboy
| posted on 13/6/06 at 08:05 AM |
The easiest way to get the correct length is to cut an old belt to the correct length then take to motor factors.
Remember to allow for stretch when tensioned.
Regds
Ian
big_wasa
| posted on 13/6/06 at 09:17 AM |
Second Halfords, spent over an hour finding mine. Halfords own belts have a number that refers to the length ie Halfords HB925g as fitted to most late
diesel fords, its 925mm long and the g is the belt type.
If you just ask for a belt of that type and length they will just ask for make/model.
Krismc
| posted on 13/6/06 at 04:39 PM |
I originally went to halfords and no luck, seem to go right up to 980 then jump to 1045mm!
I took to a belt manufacture, bearing specialist and the both said no!!
ill try a motor factors instead then!
BKLOCO
| posted on 13/6/06 at 05:15 PM |
Try BSL
Tel: 0870 240 2100
They will supply just about any lenght/width belt you require.
Krismc
| posted on 13/6/06 at 05:19 PM |
You know what it is, for work ive always used BSL on tyne bridge newcastle for belts- i left this alternator belt to last minute went there and they
have shut down!!! didnt relise it was a big company!!
cheers
