donut
| posted on 21/6/06 at 06:23 PM |
Engine build oil
Can anyone reccomend which engine build oil to use. The engine i'm building will be built over a good few months so i would rather not use
normal engine oil.
Ta
| posted on 21/6/06 at 06:32 PM |
Graphogen ? should be able to get it from your engine parts suppliers. Although not oil it is more like grease that is formulated for assembling
engines .
| posted on 21/6/06 at 07:01 PM |
I used to use an oil can with some engine oil and STP mixed when putting things together and I never had any problems.
Paul (Notts)
| posted on 21/6/06 at 07:03 PM |
MPZ ENGINE ASSEMBLY LUBE,
Building a V8 like you over a few months- The above seems to stick like glue to the bearings
used cam shaft lube on cam and graphogen on cylinder walls and rings
got all from Burton Power
[Edited on 21/6/06 by Paul (Notts)]
donut
| posted on 21/6/06 at 07:05 PM |
Lubbly jubbly
Sounds the ticket!!
Cheers chaps
mark chandler
| posted on 21/6/06 at 07:25 PM |
I would not worry as its a v8 rover.
Before you try starting it in a few months simply pluck out the distributor and make a rod (bit of tube with the end hammered oval usually does the
trick) to drive the oil pump with an electric drill.
You can then force oil everywhere before you start it, it can be a bugger to prime these engines (vaseline required around the pump gears), I have
seen people destroy new engines as the pump will not self prime, doing this makes you 100% sure its working.
You also need to be careful when using thick oil/building grease with RV8's as the oil galleries feed everything from the front (rockers,
cam/followers, Crank in parrellel), anything heavy can easily block the small drillings as pressure at the rear of the engine is low. Vasline is used
to pack the pump as it disolves quickly and melts with mild heat.
Regards Mark
andyharding
| posted on 22/6/06 at 09:47 AM |
If you're fitting new rings and have the block honed just wipe a coat of thin machine oil over the bores to stop them rusting. Lubricating the
bores will stop the rings bedding in properly.
I poured a bit of gear oil into the oil pump when fitting and spun the engine up to full oil pressure with a drill on the oil pump before starting.
[Edited on 22/6/06 by andyharding]
roadboy
posted on 25/6/06 at 04:37 PM |
Use Graphogen on all shell bearings & cams, use engine oil on pistons ,rings & bores. Fill filters, coolers & oil galleries as much as
possible with oil, turn over engine minus plugs to build pressure before starting. It is generally advisable to use a simple mineral oil for running
in & switch to fully synthetic after the rings have had a chance to bed in.
Regds
Ian
Jude Performance Services
