Author: Subject: Clutch cable
Math
posted on 30/6/06 at 08:37 PM Reply With Quote
Clutch cable
How does the clutch cable attach to the pedel, I thought that the cable would have a eye hole for the bolt to pass through, our cable has a straight end.
Also how do we adjust the pedel or do we?
robertst
posted on 30/6/06 at 11:18 PM Reply With Quote
depends what pedal box you have and what clutch cable ur referring.
if its a sierra, the pedal box has a kind of self-adjusting system which always keeps the cable in tension. the cable is connected to it through a sort of washer/stopper which makes me think in the event of it snapping i would have to get one from the dealers or a sierra one only as i dont think you can fit one of these washers to any cable.
Tom
posted on 1/7/06 at 08:19 AM Reply With Quote
The pedal has a quadrant on it so you are not pivoting the end of the cable otherwise it will fray and snap where the nipple is fitted. Capri/Escort cables have an eye fitting which must be free to swivel.
[Edited on 1/7/06 by Peteff]
Math
posted on 1/7/06 at 08:30 AM Reply With Quote
Clutch cable again
The clutch cable is for a sierra and has a straight end, I can't think how I can attach it to the pedel, I've drilled and tapped the hole as per manual...but i'm now stuck
Help!!!!
Sorry to be so thick.
andrew.carwithen
posted on 1/7/06 at 08:57 AM Reply With Quote
Doesn't the Luego use a floor mounted pedal box? (as fitted in my Avon in pic below.)
In which case, you'll need a clutch cable with an eye such as fitted to Mk2 Escorts, Capris, Cortinas etc. NOT a Sierra one!Image deleted by owner
bug1
posted on 1/7/06 at 09:37 AM Reply With Quote
Hi the clutch cable you need to have if you have fitted the luego floor mounted pedal box is part number qcc1062 which is the same as mcc1062 your local motor facters should be able to match this up I got mine straight the old Luego it has as standard the eye on one end and an adjustable part on the other if I new how to post a pic I would hope this helps.
