Author: Subject: Zetec Turbo
ZetecVan
posted on 5/7/06 at 06:47 PM Reply With Quote
Zetec Turbo
I've been reading the various Zetec Turbo conversion sites of the last few days, and am quite tempted to do the conversion on mine.
Has anyone here done a turbo conversion? Was it difficult? Was it worth doing?
Mike
big_wasa
posted on 5/7/06 at 08:22 PM Reply With Quote
Next months PPC mag has an artical on a zetec turbo install. Will have a read
Krismc
posted on 5/7/06 at 08:44 PM Reply With Quote
you can get the full kit for £1100
posted on 5/7/06 at 09:11 PM Reply With Quote
Including ECU?
peterriley2
posted on 5/7/06 at 09:21 PM Reply With Quote
that seems very steep, i dont know why more people dont take turbos off scrap production cars and 'locost' their way through it?
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
DIY Si
posted on 5/7/06 at 09:24 PM Reply With Quote
Probably because they're in the scrap yard. They'd probably need re-building, or the wrong size for the chosen application.
ZetecVan
posted on 5/7/06 at 09:47 PM Reply With Quote
Is that the turbo kit off ebay?
http://cgi.ebay.co.uk/Turbo-kit-for-Ford-Focus-1-8-2-0-16v-Zetec-engine_W0QQitemZ8053955444QQihZ019QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewIt em
Volvorsport
posted on 5/7/06 at 10:29 PM Reply With Quote
you can certainly do it cheaper than that , itll work , the upgraded fuel pressure isnt really the best way to go about it .
and that manifold is cast not tubular , looks like its off a diesel turbo variant .
the T3 turbo is obviously an ebay cheapo also , theyre £450 from garret .
The T3 from a volvo 2.3 turbo has the right trim , compressor sizes for that sort of mod , if you go looking of course .
www.dbsmotorsport.co.uk
getting dirty under a bus
scoop
posted on 6/7/06 at 07:22 AM Reply With Quote
You need the manifold and T3 from the CVH engined Escort RS turbo. Almost bolt straight on. I think that one stud needs a bit of work. Then an aftermarket ecu. You can get maps for the Pectel ecu from the guys on the Yahoo zetec group which is based in the states. Keep an eye on the Fast Ford mags for features or order back issues for relevant cars. Easy 250 bhp on low boost and no compression change
ZetecVan
posted on 6/7/06 at 01:22 PM Reply With Quote
Cheers for the info. I've got a megasquirt so the ECU shouldn't be a problem.
Who's got a turbo'd RWD car? Someone has said don't turbo it if you don't enjoy the feeling when the car comes on boost when you're midway through a corner. Makes for an interesting ride. What's your experience of this?
iank
posted on 6/7/06 at 02:14 PM Reply With Quote
Sounds like NS Dev, though he's not posted for a couple of weeks.
I think it's a valid concern that turbo lag makes turbos a bad idea for the twisty bits in lightweight cars, as coming in unexpectedly with a bang tends to throw you off the road especially if it's wet.
If you control the lag, (i.e. resist the temptation to go too large) it can probably be made to work. Might be less of a problem anyway in an Anglia Van since you're less likely to be cornering at the same G's
