ADD
| posted on 17/7/06 at 05:02 PM |
internal splined bit?
Probably a stupid question but whats the name of the interanally splined bit that the gearbox shaft slots into?
Adam
| posted on 17/7/06 at 05:21 PM |
Clutch plate if you mean the part attached to the flywheel
BKLOCO
| posted on 17/7/06 at 05:33 PM |
Ahh. That will be the "Internal splined bit on the end of the prop shaft"
ned
| posted on 17/7/06 at 06:27 PM |
the female splined thingy attached to the front prop uj !?!
beware, I've got yellow skin
stevec
| posted on 17/7/06 at 07:02 PM |
Some call it a nose.
omega 24 v6
| posted on 17/7/06 at 07:11 PM |
If its the nose of the prop then we'd call it the "yoke."
BKLOCO
Is that because it drips when the seal goes?
ADD
| posted on 17/7/06 at 07:18 PM |
I got the wrong end of the gear box. I meant to say the engine end.
jollygreengiant
| posted on 17/7/06 at 07:48 PM |
The gearbox input shaft (external splines), carries/slides into the clutch friction plate (internally splined). The shinny nose of this shaft recesses
into the spigot bearing on/in the crank shaft.
Hope this helps.
stevec
| posted on 17/7/06 at 08:07 PM |
Yep its yer input shaft.
Danozeman
| posted on 17/7/06 at 08:23 PM |
And the bit on the other end that the prop slides on is the output shaft.
Dan
ADD
| posted on 17/7/06 at 09:06 PM |
I think I have it now!!, thanks all - its a spigot bearing I need then.
Adam
| posted on 18/7/06 at 05:17 PM |
Spigot bearing isn't splined!
