darrenga
| posted on 22/7/06 at 07:57 PM |
modified sump
i have had my sump modified,just need to know how close to the sump does the pick up pipe have to be when modified.
bimbleuk
| posted on 23/7/06 at 05:50 AM |
Heres a quote from Graham "Corky" bell's Four Stroke Performance Tuning book...
"The height of the oil pick-up above the floor of the sump must also be adjusted. If it is closer than 1/4in the oil flow into the engine will
be restricted; more than 3/8in and the engine will gulp air with G forces around 0.8. Remember when measuring to include the thickness of the sump
gasket."
darrenga
| posted on 23/7/06 at 03:55 PM |
so what should it be then
se7ensport
| posted on 23/7/06 at 05:40 PM |
split the difference: I'd go for 5/16".
