markyb
| posted on 29/7/06 at 04:47 PM |
zetec query
After a lot of reading i have decided to go the zetec route (pre 95 1.8).
More than likely I will go to a scrapyard to source the engine and was wondering what else I would need from the donor
thanks in advance
scotty g
| posted on 29/7/06 at 05:13 PM |
I can't think of anything else. gearbox no good, wiring no good, steering no good.
etc etc.
Danozeman
| posted on 29/7/06 at 05:52 PM |
Get an escort engine so you get the right water pump and shallower sump.
Coil and plug leads and all sensors especially the crank if you gonna run after market ign.
Dan
zetec
| posted on 29/7/06 at 09:15 PM |
Most yards will chuck in the inlet manifold and alternator. The inlet manifold you will probably chuck away but always useful for learning how Ford
fuel the engine. Keep the coil and leads and if poss get any sensor plugs you can.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
