Author: Subject: Carburettor plumbing and wiring
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 30/7/06 at 09:27 AM Reply With Quote
Hi guys i'm at the stage now where i am wiring up and was hoping that somebody might have some pictures or could take some of a pierburg carb to pinto.
I want to make sure that the pipes are going t the right places and there are some that i'm not sure where they go/what they are.
I'll ask more detailed questions soon.
Regards Matt
cct7kitcars
posted on 30/7/06 at 09:41 AM Reply With Quote
what engine are you running
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 30/7/06 at 10:00 AM Reply With Quote
pinto 2.0
carbs mount on the left/passenger side
cct7kitcars
posted on 30/7/06 at 11:04 AM Reply With Quote
should be able to email you a picture from a manual from work tomorrow but if you want a bit of advice ditch the carb and put a weber on it lot better carb and can get them for 30 od quid of ebay
joe
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 30/7/06 at 01:41 PM Reply With Quote
Perhaps that will be a later mod, just keeping cheap and simple for SVA Will check out ebay for webers.
That would be great though if you could email that to me.
thanks matt
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 30/7/06 at 01:50 PM Reply With Quote
cct7kitcars
check your u2u for email address to send to
