FlansS14
| posted on 31/7/06 at 11:10 AM |
How far does your sump stick out the bottom,
How far does your sump stick out the bottom of your chassis, and how high is your chassis off the floor,
just need an idea for mounting my engine..
Why didn't i just make it simple!
ned
| posted on 31/7/06 at 11:15 AM |
not set the ride height yet but sump is about 2" below chassis.
beware, I've got yellow skin
| posted on 31/7/06 at 11:16 AM |
IIRC about 45mm generating a clearance of 100mm depending upon who's in it
Chassis is therefore 145mm from ground...
DavidM
| posted on 31/7/06 at 11:39 AM |
Sump is 1.75" below chassis.
Chassis height is 5.5" at front and 6.25" at rear without anyone sitting in it.
Clears speed bumps OK.
Proportion is Everything
NS Dev
| posted on 31/7/06 at 12:23 PM |
2" below chassis, 6" chassis to ground
FlansS14
| posted on 31/7/06 at 12:53 PM |
Thanks for your replys, so the average is about 5.5-6" off the ground, for some reason i thought it would be lower..
shows how much i know.. lol
Sr20det might fit after all...
Alan_Thomas
| posted on 31/7/06 at 03:34 PM |
You read the posts wrong most people, inc me, have 4" or 100mm under sump. earlier posts gave chassis to ground and sump below chassis
measurements so they average 4"
4" didn't stop me banging in the sump so hard on a 'sleeping policeman' that the sump plug was half pulled out on one side.
- Alan
FlansS14
| posted on 31/7/06 at 03:48 PM |
lol yer i ment ground clearance from the chassis to the ground just didn't word it very well... so 2" max to allow for 4" or so of
clearance
pewe
| posted on 31/7/06 at 04:11 PM |
Suggest you also consider engine height in terms of how close it will come to the underside of the bonnet. Otherwise you may find you are adding power
bulges to accomodate the rocker/cam box cover. Cheers, Pewe
