Author: Subject: Inlet Manifold Gasket
ash_hammond
posted on 1/8/06 at 04:06 PM Reply With Quote
Evening Chaps,
I am currently building my 2.0 pinto, i am going to fit twin Delarto 40's. I am in the process of painting the head and i need to mark out the gasket surface. Does the twin 40's use the same inlet manifold gasket as the standard inlet manifold. I know the twin 40's use i different style inlet manifold.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
posted on 1/8/06 at 04:24 PM Reply With Quote
let's think about this logically.
the inlet manifold woould use the same stds bolts and would need to line up on the inlet ports so it would be a pretty good guess thaqt is is the same?
crossflow is the same and I can't remeber seeing special gaskets for weber carbs but haven;t looked hard - worst case paint it all then scrape the paint of later?
mookaloid
posted on 1/8/06 at 06:57 PM Reply With Quote
Gaskets are the same
