Author: Subject: Blank radiator Cap
RobBrown
posted on 5/8/06 at 09:02 PM Reply With Quote
Blank radiator Cap
Where do I get one from?
I currently have normal ones on the rad and on the expansion tank and want to blank one off.
mookaloid
posted on 5/8/06 at 10:03 PM Reply With Quote
I'm sure QH do one if you ask at your local motor factors.
posted on 6/8/06 at 07:30 AM Reply With Quote
lococ solution would be to first remove the rubber seal and solder up the spring plungerey bit; then glue the seal back in?
DEAN C.
posted on 6/8/06 at 09:11 AM Reply With Quote
Hi,I just used a higher pressure one for the rad from halfords,theory being the header bottle will open first .
Seems to work fine.
Once I've finished a project why do I start another?
posted on 6/8/06 at 09:28 AM Reply With Quote
Q.H. used to do one for the old Austin/Morris 1100/1300 . Don't know if they are still available but if you can find a listing for these cars it may help . Can't remember any other cars using a blanking cap but i'm sure there are others. HTH
se7ensport
posted on 6/8/06 at 10:27 AM Reply With Quote
Car builder solutions do one for £6 + p&p. www.nfauto.co.uk
RichieC
posted on 6/8/06 at 12:05 PM Reply With Quote
Mine was 3 quid from local factors, just get them to rummage about.
