theohighland
posted on 9/8/06 at 10:55 PM |
alternative petrol tanks???
does anyone no of alternative petrol tanks to go in the locost as pre-made 'book' tanks aren't cheap!
i saw a tank from a Mini Van which looked ok, has anyone heard of that being used?
cheers, theo
mangogrooveworkshop
| posted on 9/8/06 at 11:00 PM |
yes
scutter
| posted on 9/8/06 at 11:16 PM |
I believe a Truimph Spitfire will work with very few mods.
ATB Dan.
alister667
| posted on 9/8/06 at 11:17 PM |
One that get's used over here a lot is a bog standard Jerry can. It carrys about 25L you can buy them brand new, then braze in all connections
etc.
Only drawback is you'll need to put in a resricted sized nozzle for unleaded only pumps if you are going through SVA.
I get a range of over 100 miles on mine which is fine for a BEC.
For a CEC you could plumb up 2 of them if desired.
[Edited on 9/8/06 by alister667]
http://members.lycos.co.uk/alister667/
Arthur Dent
| posted on 10/8/06 at 04:04 AM |
Yeah the Spitfire one will work just fine. Another is Jensen Healey but they are rarely in good shape and rather pricey.
Here is the Spit tank I picked up. Might not work with IRS though.
[Edited on 2006/8/10 by Arthur Dent]
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go
wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
procomp
| posted on 10/8/06 at 07:12 AM |
Hi the original westfield used the mini van tank.
cheers matt
Findlay234
| posted on 10/8/06 at 05:30 PM |
Anyone have the dimemsions of the spit tank??
cheers
