perksy
| posted on 13/8/06 at 10:51 AM |
2.0 VX map for ECU
Trying to Help a Mate who's 2 Litre VX on Throttle bodies is Over-fuelling Badly
Does anybody have a copy of their map that they could email me so we can compare it ?
He's using MBE and Easimap 5
But any Brand ECU will do....
Perksy
mark.perksy@btinternet.com
[Edited on 13/8/06 by perksy]
the_fbi
| posted on 13/8/06 at 11:25 AM |
Stick a post in the Mech/Elec forum on Migweb, loads of XE users with MBE on there.
http://www.migweb.co.uk/forums/forumdisplay.php?f=45
perksy
| posted on 13/8/06 at 12:11 PM |
That was me next stop
MkIndy7
| posted on 13/8/06 at 08:25 PM |
If he's using the standard Temp sender (the 2 wire on on the Thermostat housing) that could be faulty.
Not sure if its temp is displayed in the tuneing software but on the standard set-up they go faulty and cause it to run rich (as if the chokes on)
perksy
| posted on 13/8/06 at 10:24 PM |
Checked that one, Thanks
Removed Coolant Temp' sensor and checked Resistance as We placed it in Hot water and then let it cool down,
Seemed fine
Reading ok when i plug the Laptop in and check it in Easimap 5 aswell
Fuel pressure been checked
TPS checked
etc etc
Just need a map to compare...
the_fbi
| posted on 13/8/06 at 10:31 PM |
What injectors and what fpr is he running?
Would it be a good guess that it was the same guy who Blatman corrected about a MAP not being a map?
Edit: Just noticed, that was you too You're mate isn't your alter ego?
[Edited on 13/8/06 by the_fbi]
perksy
| posted on 14/8/06 at 07:45 AM |
Cream injectors mate, which according to SBD are Too small really and He needs to go bigger.
Fuel pressure is set as per SBD's info' which is 60psi
(we've tried it less than that but still no good)
The lads spent alot of money on new pistons, rebore etc and is getting Neat fuel sitting on top of the pistons
Told Him to stop trying to run it at the moment,
worried he's going to kill it with Bore wash
It was Me that Blatman 'Corrected'
That'll teach me for using capitals
I stood in the corner with me hands on me head for 30 min's
NS Dev
| posted on 14/8/06 at 12:03 PM |
not had chance to read off of the above.
Yep, have several MBE 956 maps for VX on 48mm or 45mm throttle bodies but the problem sounds more than mapping??
If you want a copy of the map email me on n.seviour@ntlworld.com.
He has verified voltage on throttle pot at closed throttle position etc etc hasn't he?
email or u2u for more info.
perksy
| posted on 1/9/06 at 11:18 AM |
Just an Update if Anybody has a similar problem
After checking the Crank sensor with an Ocilescope it was giving some very strange readings under 3000rpm
Crank sensor was Changed But the Over fuelling problem was still there
Sent MBE ECU to Steve at SBD and He found an Internal problem with it
Fixed it, sent back by special delivery, fitted to the VX and it runs a good'un
Thanks for the Sugestions
[Edited on 1/9/06 by perksy]
