iscmatt
posted on 13/8/06 at 01:32 PM |
Do i need a fuel pump?
When i got my 2.0 pinto from MK the part where the fuel pump attaches to the engine is blanked and no inline fuel pump was supplied? Question is do i
need one or is there some kind of vaccum in my pierburg 2E carb? help needed, thanks
Regards matt
DIY Si
| posted on 13/8/06 at 01:39 PM |
As you've already guessed, you'll need soemthing to pump the fuel up to the carb. Most use an electronic pump of some sort.
Sun Tzu, The Art of War
john_p_b
| posted on 13/8/06 at 01:48 PM |
presumably the carb you have is just a standard sierra carb? if so then all you'll be wanting is a normal mechanical lift pump.
an electronic pump on a standard carb imo is way over the top!
built a car, built a home, had a family. lost the family, lost the home, still got the car.
iscmatt
| posted on 13/8/06 at 01:50 PM |
ok cheers jon - ignore previous post
something like this you mean
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=002&item=120018926416&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
john_p_b
| posted on 13/8/06 at 01:51 PM |
very much like that one! not sure if the transit runs at the same rate but i can't see it being a massive difference. think they are only about
15 quid from most motor factors.
[Edited on 13/8/06 by john_p_b]
