roadrunner
| posted on 24/8/06 at 07:35 PM |
zetec installation
Would anyone have an idea of cost to convert from pinto power to 2ltr zetec.
I know roughly what i need , exhaust,throttle boddies , engine even , but how much should i spend ,grand total.
thanks for your help.
zzr1100rick
| posted on 24/8/06 at 08:21 PM |
depends how far you want to go with it money wise owt from £500 to £5000
roadrunner
| posted on 24/8/06 at 08:33 PM |
It would be nice to see a good installation for under a grand.
Krismc
| posted on 24/8/06 at 08:37 PM |
yea ive spent
engine £350, lightend flywheel £200, Clutch £62, Hydraulic clutch £180, resevoir £39Starter £120, Alternator £70, belts,filters and adaptors £40,
Raceline Water and fitting kit £150, railInlet manifold £100, Exhaust manifold £250, Shortend Sump £50, Throttle boddies £100, engine mounts and alt
mounts £60 plus filters, pipe work, spun ali, samco joins etc then the Cams/head work etc £££££
....and the list goes on
basically im bloody skint, at the moment i cant even afford the SVA so im glad it aint ready!
roadrunner
| posted on 24/8/06 at 08:52 PM |
Maybe this Locost web site is loosing its way a little.
If i was looking at up to £5000 do you think i would be bothered with a zetec.
big_wasa
| posted on 24/8/06 at 08:59 PM |
I have 2 zetecs.
The first a fully rebuilt new every thing 2L with all the fancy bits and it owes me £***k.
The second (due to the above costing more than I would get for a full scratch built locost) 1.8L doing as much as I can and every thing from induction
to ignition to alternator and starter and so on is on budget for £300.
Expecting 120 bhp which isnt huge but should be good fun for the money.
stevebubs
| posted on 24/8/06 at 09:05 PM |
Mine came in about £1200 - £400 of that was the engine (now available for £100)
http://gallery.cantcatchme.net/
MattCraneCustoms
| posted on 24/8/06 at 09:19 PM |
Can anyone suggest the best place to go for a zetec? I'm after a 2l. Also any suggestions as to the best gearbox to go with it?
Regards
Matt Crane
Danozeman
| posted on 25/8/06 at 05:24 AM |
My engine (1.8 zetec) cost me 50 quid. Type 9 30 quid.
engine mounts £35 from GTS.
Megajolt for the ign 80 quid.
Bike carbs and manifold (Bogg bros) £250
Coil pack £5.
1.8 fiesta water pump £15
The 1.8s go for alot less than the 2 litres and with the 2 litres cams are nearly the same power. Just a little less torque.
DONT TAKE THE ENGINE APART. IT COSTS A FORTUNE TO REBUILD AND THEY DONT NEED IT.
I know donorspares.co.uk sell 2 litres for 180 quid and the 1.8's are less.
Type 9 from a sierra will run it a treat and can be had from breakers for sod all.
Dan
Surrey Dave
| posted on 25/8/06 at 08:53 AM |
Yes I took my big end caps off to check the shells , it cost me £18 for new stretch bolts!!
roadrunner
| posted on 25/8/06 at 11:57 AM |
Do i need a new bell housing to mate zetec to type 9 , or will it fit direct.
| posted on 25/8/06 at 06:00 PM |
Direct fit IF you use the correct gearbox , from memory the bell housing needs to be 7in from front to rear . 1.6,1.8 & 2 litre boxes should be OK
| posted on 25/8/06 at 06:23 PM |
Regards
Matt Crane
Buy a tatty Mondeo and then you'll get the lot and can sel the rest on.
M reg Mondeo 2.0S went for £100 in our local yellow paper a few weeks ago. I just missed it. DOH!
I'm sticking with a 1.8 at the moment because it doesnt need as much modifying as a 2.0L. It bolts straight up to a type 9.
So far I have spent:
engine £200
box £30
clutch £30 (new off ebay)
starter £5
ZZR1100 carbs £45
All I need is an inlet manifold, and Megajolt. Under a ton for the megajolt and I'm making the inlet myself, so sub £500??
[Edited on 25/8/06 by coozer]
Schrodinger
| posted on 25/8/06 at 10:08 PM |
If you go for the 2.0l phase 1 or 2 you will need a 1.8 water pump.
I had a 1.8 £200 brand new
2.0l cams new £30
shortenned sump £80
Lightened flywhell modified to take 2.0l Pinto clutch £100
Home made TBs made from a pair of webers given to me free
modified a manifold £50 to take the TBs
Emerald ECU reconditioned £350
Golf fuel pump and accumulator £30 from scappy
Headers £120
Produced 148 bhp
[Edited on 25/8/06 by Schrodinger]
givemethebighammer
| posted on 25/8/06 at 11:01 PM |
You may find this useful
http://www.zetec-cat.co.uk/
particularly the page "Ford Zetec - On A Budget"
