Author: Subject: Tappet pre-load RV8
Paul (Notts)
posted on 26/8/06 at 09:53 AM Reply With Quote
Tappet pre-load RV8
Any advice on setting the tappet pre load on a 3.5 RV8...
I have a Huricane cam and Rhodes lifters...
Just refitted the rocker shafts and have a set of shims that came with the new push rods to go under the rocker mounts.
How important is it ?
can I just approximate ( use the small shim and hope? )
Paul...
Agriv8
posted on 26/8/06 at 10:25 AM Reply With Quote
quite important really not dificult to do properly.
thise site shows you how to
linky :- pre-load from rpi
£20 for a set of digital verniers from Maplin and a couple of hours and the job is done once.
In my opinion its worth doing the job properly as it will help to stop those expensive rhodes lifters an cam wearing out
Regards
Agriv8
wilkingj
posted on 26/8/06 at 02:36 PM Reply With Quote
I just bashed a bit of fencing wire at the end until I had a pair of Max / Min Feeler gauges of the right size.
Basically simle job, tedious, but quite necessary. I have two noisy tappets one on each side, and will have to level up the valves.
Before you start, check ALL the tops of the valve Stems are the same height, or you will tear your hair out. Get these the same height before you do anything else, It makes life a lot easier. Or if they are uneven, then the overall gap is very minimal.
[Edited on 26/8/2006 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
