Steve Lovelock
| posted on 30/8/06 at 06:10 PM |
Sump - which one?
I am looking in scrap yards for a suitable sump to cut and shut for my Luego Velocity using a Vauxhall redtop engine.
Does anybody know which cars have the metal sump that fit the redtop engine?
MkIndy7
| posted on 30/8/06 at 07:04 PM |
The 8 Valve Vauxhall engines have the same block and very similar bottom end, only with the steel sump where there 16v has an ali one for better
cooling amongst other things.
If its for RWD use people use the "big wing" Manta sump I believe.
Stu16v
| posted on 30/8/06 at 07:12 PM |
The 2.0 8v VX engine uses the same block as the 16v, and comes with a steel sump...
