whitestu
| posted on 31/8/06 at 06:37 PM |
Which bike carbs have a TPS?
My medium term plan once the Indy is SVAd with the CVH engine is a 1.8 Zetec with bike carbs and megajolt.
Which bike carbs would be most suited to this application?
I'll need a TPS for the megajolt so might as well get bike carbs with one on already.
Stu
big_wasa
| posted on 31/8/06 at 06:42 PM |
R1
stevec
| posted on 31/8/06 at 06:43 PM |
Later model ZX6 and ZX9 do. Plus others to follow.
Steve.
zilspeed
ZX6 carbs definitely have a throttle pot.
givemethebighammer
| posted on 31/8/06 at 06:56 PM |
Later model honda keihin carbs - my Blackbird ones have (1997/8 on at a guess)
westf27
| posted on 31/8/06 at 07:26 PM |
kawasaki xrx 1200s keilins
555
se7ensport
| posted on 31/8/06 at 09:59 PM |
ZZR1200 keihin's do, TPS on right hand end. 48mm bore as well!
the_fbi
| posted on 31/8/06 at 10:01 PM |
Blade 919 ones do too (guessing same carbs as the Bird).
givemethebighammer
| posted on 31/8/06 at 11:09 PM |
almost - blade ones are 38 or 40mm bird ones are 42mm, otherwise (jets etc aside)identical.
But then I'm just nit picking
MikeR
| posted on 1/9/06 at 07:56 AM |
Now where can i get a replacement TPS from to fit one of these without spending a fortune?
Honda recon'd that you had to buy the whole assembly at x hundred quid when i last asked
soggy 3
| posted on 1/9/06 at 11:38 AM |
why go through the effort of changing engines just fit bike carbs to your cvh? surrey dave has done it and i am in the process of doing it now i am
using zx9 kawasaki carbs and they also have a tps at the end.
| posted on 1/9/06 at 12:27 PM |
Because the Zetec is a better engine.
soggy 3
| posted on 1/9/06 at 01:23 PM |
then why not fit one in the first place?
and as for being a better engine ,yes but it depends what you are going to use the car for to fit a zetec dont forget he will need engine
mounts,exhaust man,plus a list of small jobs my 1.8 runs with a 1.6 head and different pistons plus a few other mods all of which could be done a lot
cheaper than an engine change and will produce a nice torquey motor with decent hp,the cvh gets a lot of bad press some of it is justified be we ran
an heavly modded xr3i + xr2i in 750 mc hot hatches and when we worked right tuning route the engine was v powerfull and very reliable.
will step of soap box now.
[Edited on 1/9/06 by soggy 3]
NS Dev
| posted on 1/9/06 at 02:18 PM |
another take on this one, why fit the carbs????????????????????????????
Surely if you are buying megajolt and bike carbs, it will cost almost exactly the same to fit bike throttle bodies and megasquirt?????????????????
Fitting mapped ignition without mapped injection when there are no rules to comply with doesn't make sense to me when the cost difference is
naff all, especially if you can find somebody with a map that is close to right, which you will for a zetec on megasquirt!
