darrenga
| posted on 31/8/06 at 08:38 PM |
fuel pump
what is the best fuel pump to use with twin 40 webbers on a 2.0 pinto,and where can i get one in the manchester area
| posted on 31/8/06 at 08:45 PM |
what exactly do you mean by best?
best performance?
best price?
best reliability?
there a lot of pumps that will do the job providing they supply sufficeint fuel at the right pressure for the carbs.
the pinto engine mechanical (?) pump should be fine; if you are going for an electric one, then look at the facet ones.
they are low psi - which is what you want - and are more than adequate flow rate wise.
either the cylindrical diaphragm ones or the cheaper solid state will be fine.
darrenga
| posted on 31/8/06 at 08:48 PM |
was looking at the facet ones but didnt know which one to go for.
anyone know anywhere in the manchester area that does them
big_wasa
Ebay Link .
Is what I am going to use . High volume low presure.
nib1980
Try the link below, and scroll down the page, I found it very helpful for my set up
best of luck
http://www.racetep.com/webfuelspark.html#webfuel
