Author: Subject: Zetec Flywheel
whitestu
posted on 2/9/06 at 09:35 AM Reply With Quote
Zetec Flywheel
Anyone know if a 1.8 CVH flywheel will fit a 1.8 Zetec?
lsdweb
posted on 2/9/06 at 09:40 AM Reply With Quote
Yes
Direct fit but you may need to dril the bolt holes out by a mm
Wyn
scotty g
posted on 2/9/06 at 09:55 AM Reply With Quote
Alternatively why not use a 1.8 zetec flywheel?
Surrey Dave
posted on 2/9/06 at 10:09 AM Reply With Quote
If you use a CVH flywheel / clutch do you still need the ct133 release bearing?
does anyone know the weights of the CVH and Zetec 1800 flywheels .
whitestu
posted on 2/9/06 at 10:36 AM Reply With Quote
Haven't got one, but do have a 1.8 CVH one with a new clutch.
If the zetec is better I'll get one but if no difference might as well drill out the holes on the cvh one.
lsdweb
posted on 2/9/06 at 11:36 AM Reply With Quote
Having no crank pickup is your only problem with the CVH one
posted on 2/9/06 at 01:22 PM Reply With Quote
Unless its from an EFI model...
whitestu
posted on 2/9/06 at 01:45 PM Reply With Quote
What about fitting the CVH crank pulley onto the zetec as this has a pick up on it?
Would need to make a mount for the sensor but that should be quite easy.
lsdweb
posted on 2/9/06 at 09:52 PM Reply With Quote
I fitted part of a CVH trigger wheel onto the Zetec pulley (can't remember why!) - looked like this
Wyn
whitestu
posted on 4/9/06 at 08:43 AM Reply With Quote
The standard CVH pulley fits straight on to the Zetec crank, but unfortunatley the pulley is then too far forwards to drive the water pump.
I guess it is probably going to be easier to get a Zetcec flywheel.
Should have bought an engine with one on in the first place!
Stu
