| posted on 9/9/06 at 03:30 PM |
EDIS Module
Are these any good for the Megajolt system? I have spent a very dirty 45 mins in the local scrappy and this type is all I can find.
http://cgi.ebay.co.uk/ESCORT-MK4-XR3I-ORION-EFI-90-SPEC-EDIS-MODULE-GENUINE_W0QQitemZ160027669236QQihZ006QQcategoryZ21654QQssPageNameZWDVWQQrdZ1QQcmdZ
ViewItem
paulf
| posted on 9/9/06 at 05:32 PM |
Yes it is the correct one , any edis 4 will work.Make sure you get the connector and as much cable as you can salvage from the loom as well as the
coil and connector plug and crank sensor.The fiesta crank sensors are the easiest ones to remove and get the coil from a mondeo or zetec escort as
they are the easiest to remove them from.
Paul.
| posted on 9/9/06 at 09:34 PM |
Cheers guys, I have all the other bits no problem. I got a 1.8 zetec engine that came with all the other bits. The edis part is all I havent got.
I'll be down there tommorrow to get it...
Thanks,
