Author: Subject: Vernier Pully's - Worth it?
pajsh
posted on 16/9/06 at 09:23 PM Reply With Quote
Are vernier pully's really worth having if you have megajolt.
I know MJ controls ignition and the pully controls valve timing but given the control offered by MJ is it worth having a VP too or not.
Is the OEM pully likely to be that far out??
I used to be apathetic but now I just don't care.
nitram38
posted on 16/9/06 at 09:33 PM Reply With Quote
It will always be better using verniers to get the best from your cams, but you can always fit them at a later date and use the standard ones for now.
It is more important if the cams are not standard.
caber
If you are keeping originl cam probably not worth it. If you are using an uprated cam then timing is necessary to optimise valve events due to extended durations.
Caber
