| posted on 19/9/06 at 01:40 PM |
volumetric efficiency?
can it be over 100% for normally aspirated engine? (I've read that by careful design of valve timing it can but onoy over a limited range).
anyone confirm or otherwise, perhaps with linky to web site that discusses this?
ta.
clockwork
| posted on 19/9/06 at 01:47 PM |
Look up "pulse tuning"
or read
http://www.pumaracing.co.uk/power2.htm
EDIT: er yes it can be over 100%
[Edited on 19/9/06 by clockwork]
| posted on 19/9/06 at 01:56 PM |
perfect!! thanks.
NS Dev
| posted on 19/9/06 at 02:09 PM |
yes, it can, as no doubt explained by Dave Baker in the article above.
smart51
| posted on 19/9/06 at 02:48 PM |
Volumetric efficiency is the amount of air that gets into the cylinders compared with the volume of the cylinder. Because there is a slight vacuum in
the inlet manifold, volumetric efficiency is usually less than 100%
Engines are designed with valve overlap. The speed of the exhaust gases would create a partial vacuum in the exhaust manifold if there was no
overlap. instead, this "suction" helps draw in a fresh charge. The same applies to the inlet valve timing. the valves can be timed to
close just after BDC. this allows the inlet air velocity to force a little bit more in before the valves close. Add a bit of ram air and you might
just squeek over 100% volumetric efficiency. Or you could fit a turbo.
matt_claydon
| posted on 19/9/06 at 04:39 PM |
And if you're talking about filling in the table for an FI system then unless your req_fuel (as it's called in Megasquirt) is spot on then
your VEs in the table may be well above or below the genuine value being acheived.
Findlay234
| posted on 19/9/06 at 04:50 PM |
yes its all in the pulse tuning to do with intake and exhaust length. look for previous threads on this subject
martyn_16v
| posted on 20/9/06 at 09:01 AM |
The VE table in MS is a bit misleading, it's not actual VE the table is based on. The values are actually VE / lambda, so where the table is set
to produce an AFR of 14.7:1 (lambda=1 for petrol) then the value is the actual VE. In areas where you want a richer outcome (i.e. lower lambda) then
the value is higher than the actual VE, hence why you'll see a lot of tables with values way above 100 at WOT.
