Author: Subject: What size fuel pipe?
nib1980
posted on 20/9/06 at 08:01 PM Reply With Quote
Hi all,
I've just fitted my brake lines, and am moving onto the fuel line now. What size pipe do you all use? can i use the same as the brake lines?
I'm running twin 40's on a xflow
many thanks in advance
RazMan
posted on 20/9/06 at 08:21 PM Reply With Quote
I used 8mm bore which seems about right
Raz
nib1980
posted on 20/9/06 at 08:24 PM Reply With Quote
excellant, many thanks
snapper
posted on 20/9/06 at 08:38 PM Reply With Quote
8mm microbore central heating copper pipe B&Q cheap for loads but carefull when you bend it, may be worth getting one of those small hand pipe benders for the tight turns. I destroyed half the pipe by bending it to far.
DavidM
posted on 20/9/06 at 10:06 PM Reply With Quote
Allens Motor Services in Arthur Street sell 8mm copper pipe by the foot. It's not expensive. If you need any plastic P clips to fit it I've got some you can have.
Proportion is Everything
JackNco
posted on 21/9/06 at 12:18 AM Reply With Quote
I thougth u coudlnt use pure copper pipe for fuel lines? correct me if im wrong?
And the BnQ stuff is pure copper, i used 2 work there
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
posted on 21/9/06 at 08:54 AM Reply With Quote
NO!!. brake pipe I.D. is tiny.
As folks said, either copper tube, 8 mm minimum I.D. or rubber hose. If the latter, it has to be marked suitable for petrol.
re: copper and fuel - there as some post somewhere (narrows it down a bit) that copper knackers the fuel injectors ... but that would be very high mileage and doubt any one here needs to worry about that, so go for it.
Findlay234
posted on 21/9/06 at 10:54 AM Reply With Quote
try tifosi, sells a really nice very lightweight fuel pipe (about 9mm ID) seems to be some kinda alloy and its got a very thin plastic protective coating over the pipe. Bought ages ago but seem to remember it wasnt that dear. Maybe not as cheap as B&Q copper though
iank
posted on 21/9/06 at 12:25 PM Reply With Quote
John
You're wrong well kind of anyway... there was some concern from professional fuel systems/fuel additive designers that over a long period of time (i.e. production car milages) it would cause injectors to gum up. Most here have used it with no reported problems.
No safety problems, well SVA are happy with people using it anyway.
