rpsmith
| posted on 21/9/06 at 02:23 PM |
K&N Filter Cleaning
What do any of you use to clean your air filters, i have a K&N filter (on my tin top) and was wondering if there is anything suitable to clean it
without buying the over priced K&N stuff
Rich
martyn_16v
| posted on 21/9/06 at 02:38 PM |
go to a motorbike accessory shop and get filter cleaner from there, same stuff but half the price.
rpsmith
| posted on 21/9/06 at 03:07 PM |
What actually is it, is it just degreaser?
| posted on 21/9/06 at 03:20 PM |
Probably some form of detergent...
rpsmith
| posted on 21/9/06 at 03:24 PM |
Has anyone ever tried using houshold detergent, or am i best to buy the proper stuff
Jon Ison
| posted on 21/9/06 at 03:25 PM |
For what it costs and how often you do it you may as well get proper stuff, don't use petrol and don't wash it from the outside in if that
makes sense ? Any running water from the inside out.
DIY Si
Probably best to buy the proper stuff. Oh, and make sure you re-oil it too, or it won't filter much out.
Sun Tzu, The Art of War
| posted on 21/9/06 at 03:29 PM |
True - it's a bit pricey, but it lasts for ages as you'll only use it occasionally.
| posted on 21/9/06 at 03:36 PM |
why can't you use petrol?
iank
| posted on 21/9/06 at 04:06 PM |
Why use anything but the proper stuff, how much does an engine re-build cost? Compared with that £4 a clean+reoil (even given demon thieves prices)
isn't much - it's not as if you need to do it very often unless you're an offroad racer/grasstracker.
You need the oil anyway as it's not normal oil as it's formulated to be sticky.
Sacal
| posted on 21/9/06 at 04:21 PM |
It melts the glue holding the filter together and degrades the foam too.....I do a LOT of offroading on the bike and clean the filter every week, a
can of cleaner and a can of filter oil last me about a year, you only need a little of each. Use the cleaner first to break down the sticky oil then
wash with washing up liquid after....leave it to dry COMPLETELY then spray some filter oil on the outside and stick it in a plastic bag to work it
through.
You can work it in with your hands, but you will feel stickiness for a couple of days at least
zetec7
| posted on 21/9/06 at 04:49 PM |
I use my parts cleaner bin to clean these. I wouldn't use soap or water - it takes a long time to dry, and it might be difficult to remove all
the soap. What is recommended is: 1) rinse the filter clean with a "high-flash point solvent" (such as good old-fashioned paint
thinner). As previously stated, rinse from the inside to the outside of the filter (so as not to drive particles deeper into the filter) until the
solvent runs clean through the filter element. 2) I use a compressor with low-moderate air pressure to blow the filter dry (again, from the inside
to the outside). When it's dry, 3) re-oil the filter - you can use proprietary spray-on filter oil, or you can just put some regular (new)
motor oil on a cloth or sponge, and dab it on to the element until the outer surface is LIGHTLY covered. Now you're done!
indykid
| posted on 21/9/06 at 06:09 PM |
wow zetec7, it's almost like you read the instructions, and then did everything it told you not to do!
if you're not going to use a k&n recharge kit, what was the point in buying the k&n filter in the first place? they obviously have
something in their formula.
buy a k&n kit. the instructions are in the box
tom
nitram38
| posted on 22/9/06 at 05:17 AM |
I just wash my filter in soapy water and give it a quick spray of wd40.
