Author: Subject: Useful locost info
mars103
posted on 21/9/06 at 04:28 PM Reply With Quote
Useful locost info
some info i thought is useful...
the rover V8 is in fact lighter than the essex V6
Rover 3500 V8 318 lb
Ford "essex" V6 379 lb
http://locost7.info/files/engine/EngineWeights2000.htm
A company called "mellard" will supply steel that is fully cut to length and angle for the locost chassis for £70 delivered (this will make the chassis and transmission tunnel with a 2mm wall thickness) (01782 744777) they are based in stoke but i belive they will deliver nationwide
Airproducts charge £21.50 per refill on the medium co2/argon mix with a 30p/day rental wheras BOC charge £42 per refill with a £52 Rental charge
So if you were to get all of you RHS chassis tubes cut and you welded them over a month Airproducts would be much cheaper than BOC.
I hope this is useful to at least one person
Im hoping to get my build underway at the weekend
Cheers Matt h.
im going to live forever or die trying
truffles
posted on 21/9/06 at 07:44 PM Reply With Quote
yeah thankyou it helped me out been looking for 25mm rhs for a month or 2 now so thanks i shall phone them tomorrow
