Author: Subject: Help wanted please
jacko
posted on 25/9/06 at 04:25 PM Reply With Quote
Help wanted please
Hi all - can someone please give me the measurements from the rear flange that bolts to the diff to the centre bearing mounting bolts? Also can you tell me the width of the plate that mounts the centre bearing. This is so I can weld a plate in the chassis in the correct place for bike engine conversion. Thanks Jacko ps this is to suit sierra diff in mk chassis
[Edited on 25/9/06 by jacko]
posted on 25/9/06 at 06:51 PM Reply With Quote
Graham, have you seen the light at long last, or are you modifying someone elses Indy ready for the bike engine conversion
Phil
Apologies for not responding with an answer to your question
jacko
posted on 25/9/06 at 06:58 PM Reply With Quote
Hi Phil no it's not mine [ up the pinto power ] it's Tim and Tom windmills car
Graham
posted on 25/9/06 at 07:10 PM Reply With Quote
Thought it might be. Oh well never mind, there is still hope for you yet..........
Phil
jacko
posted on 25/9/06 at 07:12 PM Reply With Quote
ONE DAY
tom windmill
posted on 25/9/06 at 09:54 PM Reply With Quote
!!!I have seen the light!!!!
jacko
posted on 26/9/06 at 08:08 PM Reply With Quote
Hi - don't you builders have a prop you can measure for me thanks
Jacko
jacko
posted on 27/9/06 at 09:51 PM Reply With Quote
No one fitting a prop then
posted on 27/9/06 at 11:15 PM Reply With Quote
I have a Sierra prop if you just want the measurement from the rear face to the bolt centres I'll measure it tomorrow. If you are mounting the centre bearing with M12s I would go with something like 40x3mm for the plate
jacko
posted on 28/9/06 at 03:36 PM Reply With Quote
THankyou Peteff thats what i need measurements Graham
