MattWebster
| posted on 2/10/06 at 11:48 AM |
Zetec 1.8 105 or 130?
Hi All,
Does anyone know which 1.8 Zetec (Silver Top) engine spec the following cyclinder head number refers to? Is it the 105/115bhp or the 130bhp head?
I'm lead to believe it's the 130 but I'm not sure.
958M 6090BC
Danozeman
| posted on 2/10/06 at 12:31 PM |
Do u know what the engines out of??
Theres not many standard 130 1.8's about. IIRC they were in the escort rs..
Dan
MattWebster
| posted on 2/10/06 at 01:19 PM |
Not sure if it's been in anything. It's a new engine done zero miles apparently, all ports are sealed. The previous owner bought it
"Unused from a kit car garage " All I know is the Cylinder Head number 958M 6090BC.
procomp
| posted on 2/10/06 at 02:17 PM |
Hi the only real way to know what psi engine you have is to check the cams by looking at thier casting rings between the cam lobes.
cheers matt
scotty g
| posted on 2/10/06 at 07:58 PM |
The number on mine starts with RY then some numbers then ends with RKA, not the same as suggested above so what does this mean??????????????
david walker
| posted on 2/10/06 at 08:29 PM |
Stuart G's engine codes specify the the engine type. You hare quoting the engine serial number.
A Ford engine number starting with RY means it was manufactured in February 1994
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
mad4x4
| posted on 2/10/06 at 08:37 PM |
If you send the engine number to for they will tell you not only the age but if it is a 115 or a 130
Scot's do it better in Kilts.
MattWebster
| posted on 4/10/06 at 03:28 PM |
Yip it's the one off ebay. The 130 would be a nice to have and as you say it's not hard to convert with a set of cams. As it's a
direct replacent for my current engine so having a Zero miler is a plus. Hope to have it in this weekend : )
