Author: Subject: zetec cranks
ch1ll1
posted on 6/10/06 at 07:35 PM Reply With Quote
zetec cranks
hi all
well I've just stripped down the crank on my zetec (blacktop) and the shell are fucked on one!
ok now i know these cranks can only ground 10thou
so it mean a new crank !
but i also have a 1800cc blacktop which i know is good,
are the crank interchangeable?
some one said they are and its only the piston bore size that is different
does anybody know ?
cheers paul
[Edited on 6/10/06 by ch1ll1]
ch1ll1
or do i just fit the 1800 engine
JackNco
posted on 6/10/06 at 10:03 PM Reply With Quote
the stroke is the same on all zetecs as far as i knwo so shoudl work ..........
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
jollygreengiant
posted on 7/10/06 at 03:51 AM Reply With Quote
If one journal has foopahed shells, then I would not hesitate to fit new engine. The grounds for this is that, you will have a LOT of metal particulates circulating in the oil galleries and there will be some deposits left loitering in these galleries, unless you strip block and remove ALL the oilway sealing plugs and power wash the gallleries. If you just change the crank then you WILL have a crank failure waiting to happen.
