Author: Subject: cam sensor
theconrodkid
posted on 12/10/06 at 04:19 PM Reply With Quote
cam sensor
been wiring up my zetec,i came across a cam sensor,(above no 4 inlet port)cant find the plug on the loom that went on it and no mention of said sensor on megasquirt.....so do i need it?
who cares who wins
pass the pork pies
DIY Si
posted on 12/10/06 at 04:24 PM Reply With Quote
Is it the zetec equivelant of the crank sensor? Or is there one of those as well?
Sun Tzu, The Art of War
theconrodkid
posted on 12/10/06 at 04:55 PM Reply With Quote
there is a crank one as well,vauxhall have these.....but ive forgotten their perpous...awaits entry of ns dev
who cares who wins
pass the pork pies
posted on 12/10/06 at 04:59 PM Reply With Quote
You only need a cam sensor for sequential injection, or Coil On Plug ignition, so the vast majority of megasquirt installations will never need one.
theconrodkid
posted on 12/10/06 at 05:05 PM Reply With Quote
cheers mike.my injectors are wired in pairs (gixer) so i dont need it?
who cares who wins
pass the pork pies
posted on 12/10/06 at 05:24 PM Reply With Quote
No you don't. Whilst megasquirt has two injector outputs that can be fired independantly, it's still a variation on batch firing, i.e. they are not synchronised to a particular cylinders firing stroke.
TangoMan
posted on 12/10/06 at 05:28 PM Reply With Quote
However,
If megasquirt can be tailored to make use oif the signal then sequential ignition should provide a useful gain in fuel economy.
I am not sure if MS can handle it though!!
It's a bitch when they go wrong though, as they tend to on some French models.
Summer's here!!!!
theconrodkid
posted on 12/10/06 at 06:23 PM Reply With Quote
cheers chaps
who cares who wins
pass the pork pies
