Author: Subject: under hole size for M10 x 1.0
givemethebighammer
posted on 12/10/06 at 09:30 PM Reply With Quote
Further to previous post does an under hole size of 9mm sound right for tapping to M10 x 1.0 ?
I can only find info on:
M10 x 1.5 = 8.5mm
M10 x 1.25 = 8.75mm
so logically M10 x 1.0 = 9mm ?
the_fbi
posted on 12/10/06 at 09:36 PM Reply With Quote
afaik for all metric threads:
hole size = thread - pitch
so yip, 9mm for M10 x 1
flak monkey
posted on 12/10/06 at 09:43 PM Reply With Quote
Yep, that works as a rough guide. But at the end of the day it depends on the material you are tapping as well, you might find for harder or softer materials 0.1mm smaller or larger can result in a better thread being cut.
Sera
http://www.motosera.com
RichardK
posted on 12/10/06 at 10:12 PM Reply With Quote
I have a usefull little on chart on my www, (the www button below!)
Regards
Rich
scutter
posted on 12/10/06 at 11:32 PM Reply With Quote
I use THIS site when i need to work out which hole size to drill.
ATB Dan.
SeaBass
posted on 13/10/06 at 07:15 AM Reply With Quote
Get hold of Zeus Precision pocketbook... If you knew everything it covers off by heart you be very useful indeed!
givemethebighammer
posted on 13/10/06 at 06:53 PM Reply With Quote
thanks people 8.9mm hole it is
