Author: Subject: r1 clutch
steveholmes
posted on 22/10/06 at 10:57 AM Reply With Quote
r1 clutch
hi,
can anyone tell me where i can get uprated clutch springs for 2003 fuel injected r1.. and any easy ways of getting large nut off to get plate out ??? fighting with scafolding pole at minute
cheers
ruskino80
posted on 22/10/06 at 11:00 AM Reply With Quote
barnett spring conversion from fluke motorsport-works a treat easy to install-will still slip a bit till its properly warmed up(at least it does on my 5pw)
smart51
posted on 22/10/06 at 01:44 PM Reply With Quote
You don't need to take the big nut off to get the clutch plates out. I'm told an impact wrench will do it for you if you want to get it off.
I have a barnett clutch conversion. Easy to fit. I have no problems with it at all, except that I had to put a washer under the top hat thing to stop clutch slip. Maybe I need bigger springs.
Some people suggest puting 2 clutch springs on. In which case, you can get one from your nearest Yamaha dealer.
