Paul (Notts)
| posted on 25/10/06 at 02:26 PM |
spigot bearing - Grease ?
About to fit the gearbox (lt77) to my RV8
does the input shaft need any grease on the end that goes into the spigot bearing.
Paul
ps -wish me luck as I am going to trial fit the engine tomorrow.
nib1980
| posted on 25/10/06 at 02:30 PM |
good luck
Peter M
| posted on 25/10/06 at 03:02 PM |
I would put a very small amount of high melting point grease,if you have needleroller type spigot bearing you should see that it has a small grease
seal to stop any grease travelling back along the input shaft and being thrown up on to clutch.
my previous cars
my westfield build
DanP
| posted on 25/10/06 at 06:20 PM |
AFAIK you don't need any grease on it.
ther rover rebuild manual (http://www.spagweb.com/v8mini/tech_files/v8_overhaul_manual.pdf) doesn't mention it either.
HTH
david walker
| posted on 25/10/06 at 06:26 PM |
Then I suggest you throw your Rover rebuild manual away
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
Agriv8
| posted on 25/10/06 at 08:27 PM |
LOL its not that bad. Is it ?
The outer row of head bolt can be ignored
Is this Mr Walker off PPC fame ? how do you fancy having a crack at 4.2 rover v8 with VEMS, individual coils and act plenum?
Oh Ps the Bush should be sympher
( spelt wrong ) bronze so is self lubricating so id say no
Kind regards
Agriv8
[Edited on 25/10/06 by Agriv8]
Peter M
| posted on 25/10/06 at 09:20 PM |
Quote Agriv8
I agree if it is phospher bronze then no grease.
[Edited on 25/10/06 by Peter M]
my previous cars
my westfield build
Agriv8
| posted on 25/10/06 at 10:22 PM |
Yea thats what I meant you see some one understands me !!!
I knew it wasnt sinted bronze
regards
agriv8
Paul (Notts)
| posted on 26/10/06 at 05:51 AM |
Its bronze - so no grease.
Paul
| posted on 26/10/06 at 08:50 AM |
AFAIK phosphor bronze bearings require lubrication, but sintered bronze bearings are porous and are already saturated in oil when fitted.
| posted on 26/10/06 at 04:56 PM |
Used to be normal practise to store phospher bronze bushs in oil so that they were pre lubricated ready for use
