Author: Subject: Fan switch for Pinto that fits Polo rad
James
posted on 2/11/06 at 10:40 AM Reply With Quote
Just wanting to change my rad for a Polo one.
Presumably I want the fan switch to come on or off at the same temperatures as the Pinto in the Sierra for it to run optimally.
What temps does the Pinto switch at? I don't have my Heynes here to look it up.
Ideally I want to put the fan switch into the threaded hole on the Polo rad. Is the Sierra switch compatible with this thread?
If not, what switch fits the Polo rad but switches at the same temps as the Pinto?
Thanks for any info.
James
whitestu
posted on 2/11/06 at 10:46 AM Reply With Quote
Hi James
I'm not sure of the temp is operates at, but I bought a rad switch from Euro car spares for about £6.
Mine is just used to bung up the hole as the CVH has the fan switch in the thermostat housing.
If you contact them they should be able to tell you the temperature at which the switch operates - I think you can get two versions.
Stu
stevebubs
posted on 2/11/06 at 11:55 AM Reply With Quote
Yup - just bung the pinto one in there.
30mm spanner IIRC
NS Dev
posted on 2/11/06 at 12:42 PM Reply With Quote
Don't know about the pinto one specifically but don't worry too much about fan switching temps, they will be close enough not to matter, they all use water as coolant!
I'm using a cavalier 16v one as it fitted and I had it already, so there's one that deffo fits the polo rad
James
posted on 2/11/06 at 03:12 PM Reply With Quote
Ok James, time to engage brain
What I came to realise when I got to the motor factors was that the Pinto didn't have an electric fan switch did it!!!
It had the viscous fan type that ran all the time.
I'm led to believe that the Pinto is meant to run quite hot (anyone know if this is true?) so what I'm concerned about with using 'any old' fan switch is that it won't allow the engine to get up to proper operating temp.
Asking at GFS the fan switch they have which would fit the Polo/Golf rad is a 95-84°C switch. So maybe I'll use this????
James
ch1ll1
posted on 2/11/06 at 05:17 PM Reply With Quote
from the autodata says the pinto stat opens @88 deg
so i wouldnt think it would be far off
[Edited on 2/11/06 by ch1ll1]
Danozeman
posted on 2/11/06 at 05:42 PM Reply With Quote
Thats what iv got in my zetec. From GSF cost me about 6 quid. There was a few variations of temp too. I reckon that ones spot on for pinto IMO.
Dan
stevebubs
posted on 2/11/06 at 06:22 PM Reply With Quote
James
sounds reasonable. Think my zetec one is similar - I just went into camberley autofactors and said "I want something like this but in a different termperature" and they brought me out a selection.
greggors84
posted on 2/11/06 at 10:04 PM Reply With Quote
Got a polo rad on my pinto. The fan switches on around 85 deg, maybe a bit more. Seems fine though.
i actually got the switch from a mk2 golf at the scrap yard but would imagine its similar to the polo one.
Chris
The Magnificent 7!
NS Dev
posted on 3/11/06 at 07:58 AM Reply With Quote
James
Engage brain again mate!
Running the fan will not substantially affect the running temp of the engine, the thermostat will see to that. Also most modern engines will run hotter than a pinto anyway......
don't worry!
