goodall
| posted on 13/11/06 at 07:08 PM |
K-series 1.4
i have a MPi 1.4 dohc, i know it is a rather torquey engine but i want to know if its any good in a seven alike and how much horse power i can get out
of it?
[Edited on 13/11/06 by goodall]
mookaloid
| posted on 13/11/06 at 08:01 PM |
Well Caterham use this motor in their base model theirs is quoted at 105 BHP and 6.5s to 60 so can't be that bad....
| posted on 13/11/06 at 08:18 PM |
Not a very torquey engine at all - but one that loves revs power output depends on exact spec model it came out of. But low ouput specs engines from
entry level 200/25 models are easy to uprate to 104ps
Humbug
| posted on 13/11/06 at 08:23 PM |
I've got the 1.4 with standard ECU etc., just a different air filter and I would say it's good enough!
If you haven't got one already, either replace the the throttle body with the one from the 103/4/5 bhp version, or adapt it to allow the flap to
open fully - that's the only different between the lower power one and the higher output version.
It's a nice light engine, though a little high with the standard inlet manifold etc., and I am more than happy with the performance. As
Mookaloid says, the base Cateringvan uses it. At my first track day a couple of weeks ago I got up to 110mph before runnoing out of space on the
straight.
goodall
| posted on 13/11/06 at 08:50 PM |
i already have the engine its from a rover 214 from 1995. i also already have one or two A-series engines and 3 GM OHC engines in sizes 1.3, 1.4 and
1.6 engines but i don't think much of them or i could use what ever i find in my serria donor but there not that many about so its going to be
what ever i find.
does anyone know how much power the GM engines kick out
Danozeman
| posted on 13/11/06 at 10:02 PM |
Forget the GM's that k series is a cracking engine providing you get the cooling right to save the head gasket.
Dan
