Author: Subject: strange rotating noise in second (bec)
mad dad
posted on 21/11/06 at 08:56 AM Reply With Quote
Went out a couple of days ago (mines a bec) and had a strange rotating noise but only in second????? car goes fine and no noises in other gears no slipping clutch etc maybe its the cold?? any thoughts anyone...
mad dad
posted on 21/11/06 at 08:57 AM Reply With Quote
its a fireblade engine just in case that helps
smart51
posted on 21/11/06 at 09:10 AM Reply With Quote
Can you describe the noise a bit more? Is it grinding or rattling or clonking or groaning?
When in 2nd, does the noise go away if you disengage the clutch? If so, does it come back again when you re-engage?
mad dad
posted on 21/11/06 at 09:13 AM Reply With Quote
its a like a metal to metal slightly out of mesh grinding noise!! and no its a good point i have'nt tried dipping the clutch to see if it goes will have to try it tonight if it does'nt rain............
Phil.J
posted on 21/11/06 at 11:15 AM Reply With Quote
It will be second gear f#cked, probably a tooth/teeth stripped. Second gear in motorcycle transmissions is the most heavily loaded, particularly with the increased duty cycle in a car application. Many race bike engines break second gear frequently. Get the engine out and remove the gear assembly to check before any consequential damage occurs( new gears are usually around the £60-£70 mark).
It's always worth keeping a watch on Ebay for gearboxes for sale, used bike transmissions are often sold for £20-£60 -ish. I keep 3 spare assemblies for my GSX-R engine for just such an occaision!
Phil
mad dad
posted on 21/11/06 at 11:54 AM Reply With Quote
not sure if its in my head but i am sure i can feel/hear this noise faintly when sitting stationery in the drive on tick over in neutral is this possible if its the second gear gone??? - thanks for the comments and advice
shortie
posted on 21/11/06 at 01:39 PM Reply With Quote
Alot of BEC's tend to sound like they are whining in low gears at low speeds, my advice is to just drive it like normal and then you won't be able to hear it anyway!
Seriously though as long as it drives fine then to be honest until something serious happens and you maybe can't select gears or use certain gears then I would just keep driving it.
Rich.
mad dad
posted on 21/11/06 at 02:32 PM Reply With Quote
yep they do whine especially in first - well mine does but that seems ok, it almost feels like theres a dry connection in second and its not smooth but its got new oil etc so i think i will drive it as all the gears select fine both up and down the box, theres no clutch slip, its just you get to know your own car and its sounds and this is different to normal........
posted on 21/11/06 at 06:41 PM Reply With Quote
bear in mind that fixing it now is a hell of a lot cheaper than fixing it when it pops and takes out the whole box! I wouldnt be suprised if the cost of a new box was comparable to the cost of the parts to fully recondition the existing one (i dont mean every gear, i mean inspect and replace a selection of the worn parts). This would also leave you with both a better overall box and more importantly, knowledge of how to do it next time!
mad dad
posted on 22/11/06 at 08:55 AM Reply With Quote
yep i think the advice to inspect now might be the best way forward so will get it looked at over the next couple of weeks, thanks
