Kook
| posted on 21/11/06 at 10:03 PM |
Will this Exhaust manifold fit a 1.6 mk5 cortina engine
As title says .. Does anyone know if this will fit if not what will it fit ? Cheers Paul
DarrenW
| posted on 21/11/06 at 10:10 PM |
Its not fitting to the engine that is the worry its getting it all inside the cars bodywork so it will exit at a convenient point.
Xflow or pinto?
If pinto i very much doubt it.
Marcus
| posted on 21/11/06 at 10:23 PM |
The Mk5 was a Pinto - so at least it exits the right side. Not seeing the flange, it's difficult to tell.
Marcus
Because kits are for girls!!
DarrenW
| posted on 21/11/06 at 10:29 PM |
Problem is if its a car manifold it wont have enough length to exit straight out of the bodywork. I looked at fitting a Cortina or sierra std cast
manifold in my early stages of build and steering bars and brake m cylinder were mighty close.
What is the manifold from?
DarrenW
| posted on 22/11/06 at 10:49 AM |
Ive seen this on ebay. Looks like its designed to fit the cast sierra manifold (see shape of the flange and the 2 downpipes). Should in theory be easy
to fit if you dont have the side panels on yet - ie fit engine, manifold and downpipe, offer side panel up and mark out where side exit hole needs to
be. You would probs then remove exhaust, fit side panel then refit the exhaust. Feel free to check the sanity of this first tho'.
http://cgi.ebay.co.uk/Exaust-down-pipe-fro-PINTO-two-into-one-to-fit-LOCOST_W0QQitemZ180052670187QQihZ008QQcategoryZ100921QQrdZ1QQcmdZViewItem
We just need to confirm that the Sierra cast manifold will fit the 1.6 cortina head. When i was looking at locost options im sure it was a 1.6 cast
manifold (single outlet) that fitted OK on the Sierra 2.0 Pinto so im pretty certain you should be OK. Sierra manifold, so im told, has better flow
than the earlier Cortina types.
[Edited on 22/11/06 by DarrenW]
