Author: Subject: Zetec Inlet Manifold Patterns
flak monkey
posted on 30/11/06 at 05:21 PM Reply With Quote
Might as well ask those in the know...
Are all of the zetec inlet manifold layouts/patterns the same? From blacktop to silvertop and across the different sizes?
I know pinto ones are all the same, am hoping ford continued the tradition...
Sera
http://www.motosera.com
stevebubs
posted on 30/11/06 at 06:13 PM Reply With Quote
yes. All mine are silvertop items and bolted directly to my blacktop.
[Edited on 30/11/06 by stevebubs]
flak monkey
posted on 30/11/06 at 06:16 PM Reply With Quote
Ta very much...
Next question, anyone got a pattern
Sera
stevebubs
posted on 30/11/06 at 08:15 PM Reply With Quote
Here's 2 for yah...
I think Raceline will sell you the flange...
flak monkey
posted on 30/11/06 at 08:30 PM Reply With Quote
Smart arse
Sera
JohnN
posted on 30/11/06 at 11:00 PM Reply With Quote
Bolt and port positions might be the same, but on a blacktop, for instance, the bottom front bolt is used by the alternator bracketry and the flange profiled accordingly to avoid it.
This manifold for example, would need to be pruned to fit and is much more "rectangular & simple" than the profile of the original blacktop plastic manifold.
In a previous post I said I'd drawn up an AutoCAD copy of the blacktop plastic manifold, sawtooth shape top etc and have confirmed by paper print at least, that it fits. Aluminium copy to follow shortly......
bob
posted on 30/11/06 at 11:13 PM Reply With Quote
If i can find my old zetec silvertop inlet manifold base plate i'll send it up to you so you can use it as a template,its of no use to me and i might at some point be interested in a manifold to TB's at some point.
[Edited on 30/11/06 by bob]
gazza285
posted on 1/12/06 at 03:55 AM Reply With Quote
Can you not use an inlet manifold gasket?
flak monkey
posted on 1/12/06 at 07:52 AM Reply With Quote
Thanks bob, that sounds ideal
John N would you be able to send me a copy of the autocad drwing you have done? If so I would be most greatful.
Gazza, gaskets have a reputation of being a little inaccurate, but may be a good starting point.
Thanks gents
Sera
