Author: Subject: Which bike carbs?
scotty g
posted on 1/12/06 at 05:28 PM Reply With Quote
Which bike carbs?
Ok guys and gals, i have a 1.8 Zetec and after a few changes of mind and direction i have decided that i would like to go down the bike carbs route.
What does everyone else use, what size, from what bike, what is easiest to fit etc?
Many thanks all.
Cheers.
big_wasa
posted on 1/12/06 at 05:40 PM Reply With Quote
Anything from a newish jap 600 and up. Ie anything 36mm-40mm
R1
R6
Zx6
Gsxr
Cbr
and the list goes on
jacko
posted on 1/12/06 at 05:45 PM Reply With Quote
Kawasaki ZX9R -
Jacko
TRUCKPARTS
posted on 1/12/06 at 07:04 PM Reply With Quote
This might be a silly question, but how do you jet these carbs are different sizes readily available ???
givemethebighammer
posted on 1/12/06 at 07:22 PM Reply With Quote
You can use weber DGAS/DGAV (£1.60 each)main jets in Keihin carbs (fitted to honda CBR and some kawsaki). The idle jets will probably be fine as they are.
Not sure about Mikuni carbs. I guess you can always drill the jets out to the size you want.
jacko
posted on 1/12/06 at 07:23 PM Reply With Quote
Hi Truckparts when i did my carbs i just drilled then out to 1.7mm i rang bogg brothers and thay told me the sizes to suit my engine with its mods
Jacko
Uphill Racer
posted on 1/12/06 at 10:39 PM Reply With Quote
Ruled out injection? carbs (sorry if this offends some) cant come close to a well sorted electronic injection system.
fellowes
posted on 1/12/06 at 10:55 PM Reply With Quote
I did R1 carbs and was able to order factory jets. If I remember, it was 180 for the main and 20 for the idle (not sure on the idle). I'm in the USA and was able to go to a bike dealer and buy a set of jets for $12
The R1's work fantastic....and I did them on a boggs brothers manifold
soggy 3
posted on 2/12/06 at 12:53 AM Reply With Quote
I agree ZX9R
mcerd1
posted on 2/12/06 at 12:08 PM Reply With Quote
I certainly hope ZX9R's are the right way to go....
Bogg bros. manifold for 2.0 EFI pinto with late ZX9R carbs (model 'E' ??)
[Edited on 2/12/06 by mcerd1]
