Author: Subject: R1 to Pinto
jos
posted on 8/12/06 at 01:49 PM Reply With Quote
R1 to Pinto
Ive just been reading the post re bec trumpets and it got me thinking.
Is there a reason why R1 carbs need to be mounted at an incline when married to a bogg bros for instance inlet manifold to a pinto??
Are there floats inside them & small resoivoirs of fuel or something.
I know the engines keeled over on a bike and that the exhuast exists the other side to to under the block to the rear of the bike.
Whats the ideal angle??
[Edited on 8/12/06 by jos]
DarrenW
posted on 8/12/06 at 02:16 PM Reply With Quote
On my Keihins there is a line just above the mounting face for the float bowl cover. As you say i dont understand the logic behind keeping this level when bikes are rarely upright. I can only think it aids initial start up and idling.
Are you thinking about Boggs manifold? They are very good but seem to be pricey. Having said that i got mine rough welded to be fettled by me and it is time consuming to make them look good. Per hour Boggs probably dont charge that much. The other good thing is you will have a contact and they will probs give you good advice about jetting and needle height to get it running ready for rolling road - you may then save some cash on the tune up over me.
gazza285
posted on 8/12/06 at 03:35 PM Reply With Quote
Originally posted by DarrenW
I dont understand the logic behind keeping this level when bikes are rarely upright.
The centripetal forces keep the fuel level in the float bowls when cornering, try leaning a bike over in a straight line. Anyway on a bike the carbs are mounted side to side not back to front as in a car, a better example would be like doing either a constant wheelie or a constant stoppie. It's best to either keep the float bowls at the correct angle, or you can adjust the float level to suit.
mcerd1
posted on 8/12/06 at 03:43 PM Reply With Quote
RE: DarrenW
I just got my manifold from Bogg bros. a week or so ago
Steve was very helpful and very happy so far with my manifold (but I've not had running yet)
I thought that the manifold was a bit on the expencive side too, but I got mine with carbs fitted (and serviced and first guess jetted) all for £346 which I thought was a much better deal and I didn't have to bother finding a set of carbs
[Edited on 8/12/06 by mcerd1]
IainB
Builder
Posts 236
Registered 17/11/05
Location Glasgow
Member Is Offline
Photo Archive Go!
Building: Fiat X1/9 - GRP widebody, Bike carbs, Megajolt
posted on 8/12/06 at 04:12 PM Reply With Quote
when I read the subject to this thread I thought you were considering an engine swap! "R1 to Pinto"
I hope Hellfire doesn't make the same mistake otherwise there will be trouble...
Iain (zx6r to fiat x1/9 )
DarrenW
posted on 8/12/06 at 04:20 PM Reply With Quote
I have to say after dipping my toe into the dizzy world of bike carbs i have re-calibrated my ideas about the Boggs costs. If you are on a budget they are a little hard to justify at first but when all things are considered i now believe it is a worthy investment.
With this in mind Jos i would say it is a good idea to give Boggs the carbs so they can clean them up, jet them and mount onto a suitable manifold. This way they will give you invaluable advice and probs a carb health check as well.
Compared to Webers £350 is almost a bargain for what will be virtually new carbs. im starting to wish id just saved up and saved myself some of the hassle (reminder to self - patience dear boy, patience!!!!)
mcerd1
posted on 8/12/06 at 04:40 PM Reply With Quote
New Weber 45's £350 X2 + manifold + link kit
I should have said the Steve got me ZX9R carbs because it getting harder to find R1 ones (omega0684 - care to comment on lead time for R1's)
I don't know exactly what's been done to the carbs, but they are clean and have been jetted (enough to get it running and probably enough to get through the SVA)
they deal with pinto's all the time so there first guess is supposed to be quite good - once your on the road take a drive up/ down to Yorkshire and they'll jet them properly for a small fee (which Steve told me and I forgotten)
When pick my carbs up from them (I was sort of passing) they had a guy in with a Mk1 Escort (2.1 pinto I think, big valves, big cam.....) on the rolling road getting his twin webbers tunned (45 or 48's) it sounded fantastic - the guy told me that if he hadn't had the webbers already it would be on bike carbs too
-Robert
cryoman1965
posted on 8/12/06 at 07:10 PM Reply With Quote
I expect they have changed the height of the needles through the diaphragm covers also.
N
omega0684
posted on 8/12/06 at 09:45 PM Reply With Quote
it took me about a month to find some R1 carbs and then bogg bros took 10 weeks!!!! to make my manifold when they said it would be three. imho the work that bogg bros do is very good and you pay for wot you get but their punctuality is, to say the least, SHOCKINGLY BAD!!!
rebelrider
posted on 8/12/06 at 09:57 PM Reply With Quote
how much do bogg bros charge for just the manifold ? without carbs ? any idea
DarrenW
posted on 8/12/06 at 11:17 PM Reply With Quote
About £177. If you want carbs cleaning and mounting (you supply) approx £210. At least thats what they told me a while back.
mcerd1
posted on 10/12/06 at 03:53 PM Reply With Quote
They did tell me before I ordered that R1's were getting harder to find (so it might not actually be R1 carbs I got) and they'd take around 4 weeks
Having been there I can confirm they are busy, but it was only 4 weeks for me (but I didn't care which kind of 40mm carbs I got) - so I can't complain
