Author: Subject: ZX12R Inlet ports
daviep
posted on 10/12/06 at 02:51 PM Reply With Quote
ZX12R Inlet ports
Does anybody out there know if the inlet port spacings on the ZX12R are the same as the ZZR1100 ???
Thanks Davie
russbost
posted on 10/12/06 at 03:46 PM Reply With Quote
I doubt it, think the ZX12 is a completely different lump to the ZZR1100 (which is almost identical to the old ZX10 & ZX9R).
I can measure the port spacing on the ZZR1100 if that helps? .....
posted on 10/12/06 at 05:18 PM Reply With Quote
Is this of any use? It's a ZX12R Engine.
Phil
[img][/img]
Guinness
posted on 10/12/06 at 07:34 PM Reply With Quote
ZZR1100's are about 40mm dia and spaced 75mm - 85mm - 75mm centres.
Mike
daviep
posted on 10/12/06 at 09:01 PM Reply With Quote
Thanks all, looks like a definitive no then.
Regards Davie
posted on 10/12/06 at 09:32 PM Reply With Quote
ZZR 1100 T/B are from memory 26mm? and spacing can be altered fairly easily with a little thought
