Author: Subject: engine rev rise
smart51
posted on 22/12/06 at 05:03 PM Reply With Quote
engine rev rise
If I cover the inlet to my airbox the engine's idle revs rise for a few seconds before falling off. If I take my hands away again, the revs rise again then slowly return to normal. what's that about?
rayward
posted on 22/12/06 at 05:08 PM Reply With Quote
sound like your richening the mixture by restricting the airflow,
Ray
scottc
posted on 22/12/06 at 05:43 PM Reply With Quote
you've made your own very manual choke.
roadrunner
posted on 22/12/06 at 09:09 PM Reply With Quote
Just be carefull that you don't put anything else in there.
posted on 22/12/06 at 10:18 PM Reply With Quote
Engine may be running weak ? when you cover your air box inlet it causes the mixture to richen and engine to run better until the air is all used the it runs too rich and stalls
smart51
posted on 23/12/06 at 11:10 AM Reply With Quote
Excelent advice. I just richened the mixture from 3 to 3.5 turns out and the problem has gone. The engine starts much easier from cold (2°C today) and only needs choke for a few seconds instead of a few 10s of seconds. The engine now holds its revs when the air intake is blocked and the revs drop slowly as the vacuum pressure on my hand increases. Thanks.
[Edited on 23-12-2006 by smart51]
