Author: Subject: Grooved Alternator Belts
TangoMan
posted on 31/12/06 at 10:15 AM Reply With Quote
Does anyone know if the grooves on pulleys and belts are uniform across various manufacturers.
I have the chance of a Vauxhall alternator to fit my Zetec but am not sure if the pulley wil fit the Ford belt.
Thanks,
Summer's here!!!!
flak monkey
posted on 31/12/06 at 10:16 AM Reply With Quote
There are loads of different profiles for poly vee belts. So its unlikely, but you might be lucky...
Sera
http://www.motosera.com
posted on 31/12/06 at 10:18 AM Reply With Quote
Not sure but I think they may all have the same"pitch" just count the number of grooves and somehow work out the length needed. Part numbers for Gates belts normally give the number of grooves and the length
RazMan
posted on 31/12/06 at 10:57 AM Reply With Quote
Yep, the Gates catalogue is a mine of useful info on the sizes. I would think that you could find something to fit - failing that you can always change the alternator pulley to match the crank pulley.
Raz
martthefridgeman
posted on 31/12/06 at 12:22 PM Reply With Quote
if its an oddball length or number of grooves you require try BSL (bearing servives limited) they can get just about any length / groove combination. mja
posted on 31/12/06 at 01:35 PM Reply With Quote
Although there are four different profiles for the multirib belts, almost all alternators use one PK- with very few using PL. What varies is the number of ribs used. Some use 4 ribs, some (most) use 6, occasionally 8 if its also driving something like a blower.
If you look at the Contitech website they have a PDF list for the multirib belts showing which car uses which belt....
Hope this helps....
