Author: Subject: timing
bracey
posted on 31/12/06 at 03:28 PM Reply With Quote
timing
how do you know where timing should be after losing the vacuum advance of dizzy when removing old single carb and fitting twin carbs?
cheers
bracey
flak monkey
posted on 31/12/06 at 03:43 PM Reply With Quote
What engine? And what cam?
Bit more info needed. Basically you statically set the timing by turning the crank to a certain position btdc and then setting the dizzy up to the firing point on cylinder one (usually marked on the dizzy body and rotor).
If all you have done is swapped the carbs and not changed the cam or anything, leave the vacuum disconnected, you dont need to alter anything.
All the vacuum does is give the engine more advance under acceleration, which improves fuel economy and nothing else!
Sera
http://www.motosera.com
bracey
posted on 31/12/06 at 03:56 PM Reply With Quote
its a 1.8 ohc vauxhall with piper 270 cam and twin dellortos jetting in carbs is somewhere near but want to get running so able to get to rolling road
flak monkey
posted on 31/12/06 at 03:59 PM Reply With Quote
You need about 12-14degrees idle advance with that set up. That should see you running. Set it up statically then use a strobe to check it and set it as accurately as you can. Expect the idle speed to be about 900-1000rpm with that cam.
Sera
bracey
posted on 31/12/06 at 04:03 PM Reply With Quote
thanks david now with the dizzy been at the front of the engine ,crank pully side which direction is to advance and roughly how far cheers
flak monkey
posted on 31/12/06 at 04:09 PM Reply With Quote
If the engine goes clockwise (all except honda do) then the dizzy usually goes clockwise too (check it!). If it does then turn the dizzy body anticlockwise to advance and clockwise to retard.
Sera
posted on 31/12/06 at 05:38 PM Reply With Quote
Don't judge every engine by the Pinto it was the exception rather than the rule.
Usual convention in the UK and USA was 4 cylinder dizzies roatate anti-clockwise,
flak monkey
posted on 31/12/06 at 07:26 PM Reply With Quote
Fair enough, if the dizzy spins the other way (like i said check it anyway) clockwise to advance, anticlockwise to retard... Not exactly rocket science
Sera
martyn_16v
posted on 31/12/06 at 07:34 PM Reply With Quote
It's t'other way round, it adds advance at low load/high vacuum. You should actually see more benefit than just a bit of fuel economy with a properly working vac advance, without it you're not giving enough time to fully burn the leaner mixtures at part throttle. And of course, if you're just throwing in fuel with a set of carbs anything to help waste just a little less is a bonus
flak monkey
posted on 31/12/06 at 07:41 PM Reply With Quote
Yes, apologies. I have heard that it is not wise to use vacuum advance with twin carbs, as under vacuum you get a pulse bacuase the vacuum tube tends to be connected to only one runner which can lead to variation in timing.
Up to you, do as you like. Was only a suggestion.
Sera
bracey
posted on 1/1/07 at 05:34 PM Reply With Quote
with timing advanced getting poor throttle response and bangs and flames from exhaust?
