flathatmat
| posted on 6/1/07 at 07:01 PM |
Pinto Camshaft Bearings?
Has anyone ever changed their own camshaft bearings on a pinto? It says in the manual it is best left to an engineering shop but i have managed to get
the old ones out with not too much trouble and it seems it is just a matter of pulling the new ones in??
Any advice would be appreciated
Thanks in advance.
paulf
| posted on 6/1/07 at 07:17 PM |
You need to pull the new ones in using some studding and a couple of washers etc.Then try the cam , it may be a bit tight and if so it is possible to
polish the high spots carefully with some scotch bright but if fitted carefully they should be ok.
Paul.
locoboy
| posted on 6/1/07 at 07:38 PM |
I did a set using some studding and suitable sized sockets.
Make sure its square before you bollock it up though!
Locoboy
macnab
| posted on 6/1/07 at 11:24 PM |
done it before as well, not difficult but just take your time.
flak monkey
| posted on 7/1/07 at 10:50 AM |
Did mine, made some pullers on the lathe to prevent the new bearings distorting when they are pulled in. They are pretty tight!
Sera
http://www.motosera.com
