itguy
| posted on 8/1/07 at 11:25 AM |
zetec crank toothed pulley removal :(
hi everyone
anybody got any good tips for trying to remove the crank toothed pulley on a zetec?
I've tried to inch it forward a bit from the rear but its now not moving any more. I presume the woodruff key should be left in during
removal?
It just looks too tricky to get one of my pullers on it too - not enough space!!
whitestu
| posted on 8/1/07 at 11:27 AM |
Mine moved really easily - A 3 legged puller should get it off if it is tight - sorry - just fully read your post.
If you can't get a puller in not sure how you would do it.
Stu
[Edited on 8/1/07 by whitestu]
itguy
| posted on 8/1/07 at 11:38 AM |
how did you get a puller on it? Isn't your oil pump surround in the way?
DIY Si
| posted on 8/1/07 at 11:41 AM |
Is there any way of getting a pry bar or two in behind it? Or a couple of long screwdrivers?
Sun Tzu, The Art of War
whitestu
| posted on 8/1/07 at 12:04 PM |
Maybe yours is different - mine is a 1.8 Blacktop [from a focus] and there is enough room to get a puller on it.
My initial post wasn't clear though - mine came of easily without needing a puller.
Stu
Stu
flak monkey
| posted on 8/1/07 at 12:07 PM |
If it did start to move and now its not its probably got jammed on the shaft as they are a nice sliding fit usually. Try tapping it back onto the
shaft *gently* then try pulling it off again as evenly as possible. It should come off with your fingers really...
Sera
http://www.motosera.com
TangoMan
| posted on 8/1/07 at 03:15 PM |
Good advice!! Tap it back on and apply some WD40 to help loosen any debris. If it moves at all then it should slide off. Mine was a bit stiff but I
just levered it gently off with a bar in each side. A tap on the bolt head (loosened a few threads) helps while applying leverage.
Summer's here!!!!
itguy
| posted on 8/1/07 at 08:01 PM |
great, thanks guys - I'll give it a try tomorrow.
itguy
| posted on 8/1/07 at 10:06 PM |
thanks everyone - pulley now removed. just worked it back and forth (as the saying goes)
